Alright guys,
Management is willing to spend some big bucks on upgrading our 2 B&S machines (XCEL 7-10-7 & 9-15-9), as well as get potentially 2 NEW machines. They have passed most of the responsibility onto me and my peer and as expected we are having a hard time coming to consensus on what to do, so I have a couple general questions for everyone to start.
A little background on our parts: We make small to medium aerospace parts that require holding .001 true position over 12 inches in rare circumstances. We check parts in process as well as finished parts, so the machines are running for most of a 18 hour work day. We use long styli often (greater than 50mm) so we want something that can work with the long stuff.
-For an upgrade to the existing machines: We currently have PH10MQ probe heads with TP20 triggers. Most likely going to upgrade to SP25 to accommodate longer styli.
The big questions are:
-Will the SP25 work on the legacy PH10MQ or do we need to upgrade to the PH10MQ PLUS?
-For those that have used both TP20 & SP25; what is your experience with both in terms of accuracy and reputability?
-Are there other probes/probe heads that we could consider that would improve performance with long styli?
For the new machines: We will be looking for bridge machines in the 9-15-9 size range. We will probably end up running two software's regardless, so hardware is the main focus right now.
Questions:
-If you were building your dream machine, what would it be and why? What components/accessories would you get?
-What are the major pros and cons of a fixed, continuous scanning probe head?
Thanks everyone!
Questions:
Thanks everyone!
