TGTool
Titanium
- Sep 22, 2006
- Stillwater, Oklahoma
I found the following advice on another discussion forum and I've never heard this particular caution before.
Water causes wood to swell, some chemicals cause some polymers to swell, but oil causing granite to swell? I don't know what the old fart equivalent of an old wives tale is, but is this belief in that category?
I can imagine that someone somewhere has seen a granite plate with differential temperature changes and an oily surface, leaping to a cause and effect conclusion. Or have I been that ignorant all these years? We always cleaned the surface (and the workpiece) to be sure no dirt or swarf changed a measurement but didn't get excited about oil. Not that it was ever rubbed down with oil, but parts out of the EDM tank, grinder or something else weren't seriously de-greased before measuring.
I use glass cleaner for the granite stuff. You want to keep oil off, if oil is allowed to stay on granite for an extended time, it can soak in and cause it to swell.
