peu
- Jul 9, 2006
I have a Rockwell C hardness tester that I think needs calibration, when I use the standard provided with it (64.5 +/-1 RC) it consistently reads 62, but since it was indented so many times I had doubts about its accuracy.
So I purchased some round O1, made 8 slices, hardened and then surfaced both sides so they are super smooth (they attach one to the next with a simple rub) and then distributed a few of these "soon to be standards" to friends with RC testers, all of them returned to me with the same readings 64~65RC so Im pretty confident about their accuracy now.
With one of these I keep reading no more than 62~63RC no mather what I do.
I inspected the indenter with a loupe (triplet) and I don't see any defects or cracks and is smooth to the touch.
The lever on the side when I apply the load moves slowly as it should, meaning the hydraulic spring on the back below the weights works fine (when I purchased it I refilled it because it was almost dry and the lever went from preload to full load in a snap)
I would like to tap the forum knowledge pool to help me calibrate the tester, a lab asks a lot more than I prepared to spend
I tried to adjust the reading by untightening the center screw and the knurled retainer, moved it and then retightened the knurled piece, but I keep reading 62~63RC so I guess this is not what I need to adjust.
Thanks in advance.
Here are photos of my hardness tester:
and a view from the top
Pablo
Thanks in advance.
Pablo
