Have you checked into buying some larger "standards"?
I have stds (and mics) up to at least 36", and on a feature the other day that I needed to hold tighter than a nuns c on the lathe - somewhere around ??? 18-22" maybe ??? I used both the digi calipers as well as the mics.
I don't trust big mics as you cannot feel them. Or should I re-word it to say that you can feel them less and less as they get bigger and bigger. The calipers - not so much - BUT you can't wrap around a 30" shaft with the calipers. This feature was reachable from the face, so the calipers fit fine.
So I dug out a std in the range that I was working and checked both units. Charted both as far as "reads .001 big or .0015 small". (Keep in mind that large mics will cover a 4" range generally with replaceable anvils. I used both tools as best that I could, and wrote down their readings. When I got to where both units agreed on size - it's good.
But the 24" digi calipers was off about .001 from the std that I was using compared to ZERO.
I have not had good experiences with calibration services in the past, and this was just confirmed/updated again this last week where two rings for the same size were AT LEAST .001, and more like .002+ in disagree-ance with each other. I will take the std, or in this case - the set guage ANY DAY over a sticker on a guage!
We did have the set guage in this case, and one was right on, and one was way loose.
Could you just order up a std for a size in the range that you will be needing on a job coming up - as you go? IDK how available 40"-80" stds are, nor what one might cost?
From the std tho - you should be able to work your way backwards. In my case - when I doo big bores - I doo use inside mics, but I use them mostly in the way that I would use snap guages. (But have more confidence in the mics) I always go back to the big calipers and/or mics to confirm size. Sometimes they read right on, other times they may be out .0015, depending on cleanliness of the kit, wear, and how well you (I) wrung the spacers all together upon assy. I just will not count on an interchangeable tool to be right-on at any time. It all needs checked.
Also - the 75" std will not fluctuate with temp nearly like a 75" ID ring guage would. And it fits in the cabinet much easier - and with only one person, as opposed to a forktruck tossing it on the top shelf of the pallet racking since it's too big to be anywhere w/o risking getting hit or dropped. (Boy - tha'd be a bad day eh?) But then - maybe you would want the ring to move with the temp if you are boring a ring in a non-climate controlled room? I like to let criticals set overnight sometimes.
Also - if you were to send it out to be certified (I highly doubt that they would ever "calibrate" it - as that would be a factory setting - whether digi or vernier?) at what dimmension would you have them "set" it to? It's prolly not 100% the same everywhere (as my 24" above showed), so if you have it "set and cert'd" at 60", would that be close enough when you were dooing work at 45 or 75"?
Think Snow Eh!
Ox
