allloutmx
Titanium
- Mar 6, 2013
- Rochester, NY
How would one verify an OD thread gage?
Im affraid my turkish lathe buddy is about to have a bad day
What type of gage?
adjustable ring ...class 2b thread
Huh? a Class 2B thread is an internal thread. You can't use a ring gauge for that. What is the thread diameter and pitch you want to use your adjustable ring gauge to check?
Correct, my mistake.. It is a 1/2-20 2A thread.
It's a ½" UNF thread. Your max pitch diameter should be 0.4662" and min 0,4619".
Probably cheaper (and better) to measure the pitch diameter on the components or components with thread wires or similar. At least then you'll know exactly where you are.
The diameter wires (if you choose this method) you'll need are 1.27mm or as close to that as possible. The alternative is sending your ring gauge to a calibration facility and it'd probably be cheaper buying Go NoGo thread ring gauges. It is after all a standard thread. Of course if your adjustable ring gauge needs to be set to an "unusual" pitch diameter because of the component or components being surface coated after machining then that's another matter.
Asking questions is usually cheaper than making mistakes
Gordon
is three wire going to be more accurate than using pitch mics?
we have already measured the parts as such... maj dia and pitch and pitch dia...thread gage wont go so I was hoping for my friends sake, it was the customers ring gage. Thats why I was wondering how I could verify the gage is right/wrong and not measuring the part itself.
chipped insert...thread form was off..one side of the thread looked good, the other does not.
Gage, im assuming is fine, but Would still like to know, how to verify...send it out to calibration...okay..how to "they" do it?
Are you sure nominal pitch diameter for a 1/2" UNF is .717?
Notice
