greif1
- Oct 1, 2013
- Rochester, NY, USA
I noticed a lively discussion (now closed) about whether a wringing film thickness is included in gauge block calibrations. I belive most of the world will agree that ISO Standards are the most used when standards are required, so in this sort of discussion I always look there. I rather quickly found the following:
ISO 3650:1998(en)
Geometrical Product Specifications (GPS) — Length standards — Gauge blocks
https://www.iso.org/obp/ui/#iso:std:iso:3650:ed-2:v1:en
"3.2
length of a gauge block
l
perpendicular distance between any particular point of the measuring face and the planar surface of an auxiliary plate of the same material and surface texture upon which the other measuring face has been wrung
SEE: figure 1
Note 1 to entry: The length of a gauge block, l, includes the effect of one-face wringing (see 8.3.1)."
As I have noted above- stating "chapter and verse" is a very good way to state the facts (as opposed to " read the standard".
On the other hand, this article;
http://www.metas.ch/metasweb/Fachbereiche/Laenge/Dokumente/2003 SPIE SanDiego GaugeBlocks.pdf
examines the uncertainty of optical calibration Vs. mechanical, saying that optical has the disadvantage of having to wring a block, but mechanical calibration is faster.
It appears that the optical method with a wrung block is the primary standard, but the non-wrung mechanical calibration method is also often used.
The B89.1.2M-1991 ANSI/ASME standard can be found here:
http://www.resenv.cn/Knowledge/ShowPDF?fileName=US-ASME&docName=ASME B89.1.2M-1991.pdf
The Elsmar forum (a very good metrology forum BTW) has an interesting note that there is a lot of contradictory info on wringing films (or was back in 1999 when the post was made).
http://elsmar.com/pdf_files/uncertainty/Uncertainty_Threads/Uncertainty-wringing.txt
The more I look the more I find, so I think I will stop now!
GR
ISO 3650:1998(en)
"3.2
l
SEE: figure 1
GR
