sabre1fv
- Nov 19, 2013
- Cupertino, CA
I am trying to identify what company made the levelling tables that were used for measuring flatness and perhaps other features. These were two steel plates approximately 8" square and had two solid steel 'hinges' between them and would likely be used on a surface plate. The bottom plate had a 3 point mounting system with one of the points being adjustable to level in one axis. The second plate mounted to the bottom plate with 2 solid steel hinges and one adjustment screw for adjusting the second axis. Main purpose was to be able to level a part/surface so you could then check it's flatness.
I have Googled it and looked in some old catalogs and can't find one now. I know they exist because over the years I have purchased two of them but now I don't recall what company made them. Perhaps they are called something other than a levelling table or plate....?
We could probably make one but purchasing one would be easier. Just want to measure flatness without resorting to the 3 jackscrew method.
Thanks in advance for any assistance you can provide.
-Jim
-Jim
