I am trying to figure out how to quickly and accurately measure the angle of a drilled hole on a thin walled part. The part is bicycle rim; the thickness of the wall is > 0.100. The basic geometry is an arc that is 0.100 thick and the holes are drilled at alternating angles slightly off center. We have a Micro-Vu, height gauges, gauge pins blocks etc. I cannot come up with a good way to measure the drilled angle. Gage pins move when you go to measure so it is not accurate. I am looking for any suggestions.
