So I found myself needing to measure hardness (Rockwell C) on a few parts, but i dont have a 'Rockwell C' tester. I did happen to find (believe it or not, it was up on a shelf) a superficial hardness tester (Rockwell N, T and Vickers).
I did a little research, and found the conversion tables. I need to measure up to 60Rc, and it looks like i can do that using the R30N scale.
My question is, will it really work?
If my understanding is correct the 30N is essentially the same as Rc, but with a different weight, therefore a different depth of indentation. Im not measuring rocket components, if im off a point or two, ill be OK.
Thoughts?
Thoughts?
