Bread
- Oct 4, 2013
- Ballard, WA
So we're having major issues with our micromter calibration service here in Seattle. We never had issues with our outside mic's for decades until we started doing coast guard work, which requires our mics to be certified. So we paid big money for the little stickers, and since then every single mic has had issues holding tolerance. Right out the gate, each outside mic reads .0005" big over the standard. Doesn't matter if you use the Mitutoyo clicker on the end, or just go by feel. We have a dozen machinists, and we're all getting the same results. Some of the mics are off more than .015", so they must not be tightening them properly as well. We have the same guys working here before and after the calibration was done.
I called the company and they apparently calibrate them at a temperature much greater than the ambient (unheated) temperature of our shop, which would account for a few tenths, but not 5 tenths. They must also use higher pressure than is required. They even said some of our standards were too long and ground them down! I can't imagine how a steel rod would GROW in length when there are no dings on the tips, and the tips areconstantly being polished with hardened micrometer anvils.
In any case, we aren't happy. I'm tired of figuring the .0005" into my calculations when machining and the other mics loosening up is unacceptable. I'm wondering what service other shops use for calibration. We're in Seattle, so it's nice to use somebody local but if I have to ship them out then I will.
It would also be nice if they did repair work. I use long island indicator repair for that (and they're awesome) but they're on the other side of the us.
Any input is appreciated!
