morsetaper2
- Jul 2, 2002
- Gaithersburg, MD USA
I have these two Mitotoyo .0001 mics. A 1 inch (#103-135) & a 1-2 inch (#103-136) mic. Both are off of their zero point by a lot. I suppose I could rotate the sleeve with the wrench around to line up the zero lines. But thinking that either the female threaded sleeve, or the spindle of each, was somehow rotated to the point they are now. As you can see the 1 inch zeros out at .008 and the 1-2 inch zeros out at .013 (on a 1 inch standard).
The graduated sleeve attached to the micrometer frame is exactly where its supposed to be on each. The measuring faces are nice and clean, and under magnification appear to be square to each other. These mics came in a toolbox lot I purchased so don't know their history.
Looking at the exploded view, it looks like the female threaded sleeve is somehow locked to the frame, not meant to be disassembled since its all one p/n. So thinking that the spindle has been rotated. In the exploded view it looks like the spindle can be removed. And with a taper on its end it seats into a taper on the ratchet end of the thimble? I could remove/rotate till I got the zero points close.
Interestingly enough, if I switch the thimble/spindle assy's between each the zeros are off by about .002. Parts are same p/n between the two so doing that would certainly make the mic useable. But would like to get the zero points back to where they are supposed to be.
Can anyone whose been inside of one of these mics advise on how to get the zero back where it should be. Thanks
Mitutoyo 103 Series Micrometer Exploded View PDF
