simpleminded
- Oct 15, 2010
- South Dakota
I thought that would be the case, but since I've not tried it I thought I would wait for input from someone who had.Once I ground down the probes to fit the groove , the micrometers feel was horrible and it was almost impossible to get consistent readings.
Bill,
I think we're back to someone drawing something and not thinking about whether it is sensible or feasable. A 0.008" width and a diameter of 0.242 ±0.001"? Personally I haven't a clue as how to do it without taking out a bank loan. I'll bow in awe to whoever can come up with a solution that doesn't bankrupt you.
Gordon
but the diameter and width of the disk make it very iffy.
The thickness of the probe (disk) directly affects its rigidity, and the rigidity directly affects the accuracy.
Did you notice, that they don't have equal thickness (diameter-wise)? That won't work. Where would you measure?Maybe using an internal circlip and measuring the inside diameter when in place?
A point will give problems with deformation and wear.cut a peice of .006 or .007 shim stock to a point on one end.
That would work.OK, attached are two sketches.
Notice
