BigBob
- Jan 24, 2010
- USA - Verona, VA
Short of having plates formally calibrated, anybody use these for preliminary surface mapping, and if so, how?
I use level all the time to test granite and cast iron plates. I have 2 levels, a Starrett 199 with a .0005/ 12" bubble and a King-Way 12" level with a .0003"/ 12" accuracy bubble.
I have been site testing plates with levels for 40 years and my Dad did it that way for 40 years before me.
It's not.I would never have thought in a million years that a machinist level would be sensitive enough to check a surface plate...
It's not.
- Leigh
This is generally a discussion board for professionals engaged in business and following best business practices.For the adventurous, even the sensitivity of the vial can be adjusted by flexing it.
While we encourage participation by serious amateurs, that is not meant to encourage hobby-grade methods.
- Leigh
As to "regularly scheduled checks to the calibration experts"...I suppose with the advent of CNC and regularly scheduled checks written to the calibration experts there is no reason to ever understand the foundations of accuracy and repeatability.
.On a side issue anybody with a 0.0001" per 10 inch level had better have plenty of time and patience. I used to have one, it got used every blue moon. I sold it after a while. You had time to go for a coffee before the bubble settled. Regards Tyrone
i have seen plenty of 0.0002" per 10" (0.02mm per m) in China. you are right they are sensitive. for rough leveling i always start with a 0.004" per 10" (80 arc second) 0.005"/foot level. At this rough level can measure 1/4 level division or 0.001" per 10" it is the primary level to rough in equipment. it's range of 0.001" per 10" to 0.016" per 10" is a practical rough leveling range.
a 0.0002" per 10" level can easily be off scale at 0.001" per 10" or you cannot measure more than 5 lines off.
i have a square frame level where i added a 0.004" per 10" level vial in addition to the 0.0002" per 10" level vial. That way the same level could read 0.016" per 10" down to 0.00005" per 10".
the 0.0002" per 10" vial is too sensitive most times. the heat from a flashlight can easily move the bubble. the slightest spec of dust can throw the reading off scale. yes the level bubble can be slow responding. i have read in the moore book that having a room with air temperature of 1/10 of a degree F and letting objects to be measured sit for a day so the become even temperature are basic requirements when trying to work in the millionths or even 10's of millions of an inch
.On the other hand I once got to borrow an " Hilger & Watts " electronic level. You could use it in two executions, 1) 0.001" in 10 inches or 2) 0.0001" in 10 inches. This was done with a flick of a switch. As I recall the readings were almost instant in both executions.
Regards Tyrone.
Notice
