Could you please explain the second sentence in the context of the first?
If the datum is the C/L, how does the hole diameter affect position at all??
- Leigh
Leigh, those are two separate statements referring to two different features.
For the first statement, the datum is the C/L of the minor diameter, which by definition is RFS. IOW no matter what the ACTUAL minor diameter is, it's center line is the datum.
The second statement refers to the wirehole, which can be .05 +/-.01, where "small" = .04 dia, "big" = .06 dia.
dstyr
Can't call the "picture maker" as this part is a hand-me-down from a regular customer who broke 7 ( count: SEVEN ) drills into 12 parts attempting to do it with HSS drills and no fixture.
The main question is actually kind of rhetorical as I was told to just get them holes drilled and the drill-remnants removed as they need to ship in the AM.
Location doesn't matter much, ignore print, ignore look, ignore everything, just git'r done. That, I already did do.
I'm only asking because I cannot think of an explainable reason to define wirehole locations this way.
As for a real blueprint, if anyone ever seen the drawing of a hex nut with wireholes, then you've seen them all. Plain vanilla.
Hex size, thread size, length and location of 6 x wireholes with TP callout in respect to thread minor [A] and one face
. That is it.
Similar to this:
Redirect Notice
Only to add a TP callout to dia L.
