JHOLLAND1
Titanium
- Oct 8, 2005
- western washington state
Here is a puzzlement. Just got in Newall sapphire Dro and spherosyn scales. Seller stated counter was bad. He was right. Here are some findings related to failure.
the older Spherosyn reader heads require 12 vdc and 5 vdc power. The 12 vdc regulator ic, and ac transformer are rock steady. 11.92 vdc available at plug for encoder.
When one encoder is plugged in, into either x or y dedicated receptacle the display will work for up to 60 seconds then drop out with either a 0 on the lcd strip or sometimes blank. When a volt meter is plugged into the 5 vdc female hot pin on the unused connector, a curious pattern is documented.
+ 4.75 vdc for 10 seconds
+ 500 mvdc for 10 seconds
- 4.25 vdc for 10 seconds.
this cycle is as regular as a pendulum.
one 7812 regulator ic is present and rock stable. two 7805 5 vdc regulator chips are present and output stable.
however, measuring output at two diodes shows wild fluctuation but never negative voltage. and checking capacitor shell on several adjacent to regulator chips shows lots of fluctuation but never negative.
it would seem either a capacitor or diode-- or both is at fault. but the swinging polarity is something new to me.
any thoughts?
pics
https://picasaweb.google.com/pulsenpal/FailedNewall#
jh
any thoughts?
pics
jh
