ballen
- Sep 25, 2011
- Garbsen, Germany
I recently got a Heidenhain MT30 indicator probe. This has 30mm of travel and 1 micron resolution, and works very nicely with a bunch of my dated readout equipment.
There is one thing that bugs me. The probe came with a ~50 cm long pushbutton-on-a-cable thing that is meant to retract the probe, but it doesn't work. So I took it apart today to see what was happening. The pushbutton/cable thing drives the rack gear of a small rack-and-pinion assembly; the rack was jammed, and I freed it. But there are signs that others have been here before, and did not leave everything behind, so I can't tell for sure how it works.
I think the way this works is that the pinion gear (not visible, on the other side) drives the lower aluminium wheel shown in the photo below. That wheel is supposed to be tensioned by a small string and spring. Then another bit of string that pulls the probe rides by friction on the same wheel. I found one bit of broken string still attached to the aluminium wheel, but no spring or other bits. The photo below shows what this looks like.
If someone here has one of these MT30 probes on hand, could you please remove the cover (two small screws) and take a photo of the innards for me, so I can see how it is supposed to work?
Cheers,
Bruce
Cheers,
Bruce
