Wring or not wring is the decider. Basically if they all wring together in a satisfactory manner then odds are that they will still be sufficiently close to calibration for general work. Obviously not high end inspection purposes but still good enough to track variations in micrometers or similar measuring instruments.
If they wring poorly its an open question but its probably affordable to have the faces restored and the blocks re-calibrated. Arguably starting with a poorly wringing set and having them re-polished and calibrated could be preferable to an out of calibration set that still wrings well.
If they don't wring then you have high grade spacer blocks. I have a non-wring set that does just fine to set the bed stop on the lathe and similar duties.
Always assuming they are a decent, proper material and properly heat treated, brand of course. Low end imports can be expected to move after 5 years or so but its all very unpredictable so at under 10 years even a low end set ought still to be close to calibration. Actually given that a low end set can be got for around calibration costs and decently precise probes can be got at, by historical standards, very affordable prices its arguable that setting up to track varation and buying new sets at fairly regualr intervals is a viable way to go about things. Good luck at getting that idea past an ISO9000 inspector tho'. Given an appropriate degree of low cunning and sweet talking of the laws of physics tracking variation is a lot easier than calibration but you can't use the results to give a new size. Pure go - no go.
Clive
