Hello,
I am evaluating the equipment in our inspection department. I am trying to do a simple 10:1 ratio sanity check on some of the equipment we use for tight tolerance parts (.001 or less). We do a lot of it for size and position of features.
I've read a lot of literature about the ratio and I'm confused about what number to use for the ratio: resolution of the device? Bi-directional accuracy? Total accuracy range (double the bidirectional value)?
For example. In the Mitutoyo catalog there is a simple OD mic.
Resolution: .0001 (vernier scale)
Bi-directional Accuracy: +-.0002
Total Accuracy range: .0004
None of the literature I've read is explicit about which value to use. They say interchangeably: resolution, accuracy, precision, etc.
I am leaning towards resolution of the device. But then I'm not sure if that accounts for the accuracy, which is always larger than resolution.
Any clarification would be appreciated.
Thank you.
Thank you.
