Sony DRO nightmare Hopeless?
Results 1 to 8 of 8
    Apr 2018
    Colorado
    5
    Default Sony DRO nightmare Hopeless?
    Have a DRO on my mill. Sony LH-200 with SR-2711 scales. Worked.
    Display is getting more and more flakey. Bought a LH-20 display
    that works great. Scales plug right in.
    But.... I get 0.778" displayed inch per real inch. Scale
    factor is wrong.
    Is there any hope? Bill Hale Loveland CO
    Mar 2009
    Eureka, CA
    3,297
    568
    1003
    Bill,
    Welcome to the forum. I recently had my Sony display fail and during the search for a repair answer I talked to the horses mouth. Give these folks a try, they're Sony, with a new improved name!
    Stuart
    Magnescale Americas
    1 Technology Drive, Suite F217, Irvine, CA 92618 USA
    TEL:+1(949)727-4017
    FAX:+1(949)727-4047 E-mail: [email protected]
    Jan 2005
    The Netherlands
    5,301
    219
    1207
    Is there a linear compensation active on the display
    On a LH10 if you put the power on then SONY is followed by the number of the linear compensation
    Peter
    Apr 2018
    Colorado
    5
    Quote Originally Posted by Peter from Holland View Post
    Peter
    There is but its range is extremely limited like a few thousandths. bh
    Mar 2009
    Eureka, CA
    3,297
    568
    1003
    I have no idea if your Sony display is the same as the old one I had..a LH-42, but on that unit there is a parameter to set scaling. It's different from linear compensation. The program function display is "SCALING".
    Stuart
    May 2004
    Owensboro, KY
    323
    55
    Default Lh-200
    Quote Originally Posted by Bill Hale View Post
    factor is wrong.
    Did you try taking the case off the original display and re-seating any and all connectors, circuit boards and any socket mounted ic's? That took care of the flaky issues on mine. Sometimes the connectors and plugins get a little corroded.
    Charles
    Apr 2018
    Colorado
    5
    Quote Originally Posted by fixitup View Post
    Charles
    I did exactly this because we know failures are usually connectors, etc. No joy.
    It acts like the clock has failed. I see a 4 mhz crystal on the power board. With a schematic I could probably fix it. Crystals have lousy reliability too.
    Thanks for the help. Bill Hale
    Apr 2018
    Colorado
    5
    Quote Originally Posted by atomarc View Post
    Bill,
    Stuart
    Magnescale Americas
    TEL:+1(949)727-4017
    For archival purposes, I emailed these guys and got a quick reply. The LM-20 is designed
    for metric scales. Won't work with the SR-2711 english scales. Interestingly, when I
    set the LM-20 to METRIC, it reads 20.000 per actual inch which is almost usable. Unfortunately
    changing it to diameter goes the wrong way, making it 40.000 per inch.
    BH
