Starrett telescoping gauge diffrence
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
    Aug 2017
    Illinois
    14
    Default Starrett telescoping gauge diffrence
    I'm looking to upgrade from a set of almost useless Chinese gauges. Can anyone tell me the diffrence between the Starrett 229 series and the 579 series telescoping gauges? Thanks
    Mar 2013
    Cerritos, CA
    324
    109
    126
    579 is a longer reach
    Mar 2013
    Cerritos, CA
    324
    109
    126
    My previous post seems to be incorrect - making your question a very good one - I so far can’t see a difference
    Mar 2013
    Cerritos, CA
    324
    109
    126
    I found the answer: the 579 has two telescoping contacts.
    Aug 2017
    Illinois
    14
    I believe your correct after looking at them again on the web. Any preference or opinions on them. Is one style more user friendly?
    Dec 2014
    CANADA
    British Columbia
    713
    249
    332
    I prefer the single sided contacts, the less moving the better IMO. In reality I like having a fixed point to apply pressure to because it find it easier to find the high spot.
    That said, I own a set of mitutoyo doubled sided and don't feel like I do any worse work with them.
  7. Likes Matt_Maguire, ManualEd liked this post
    Mar 2012
    Geilenkirchen, Germany
    1,894
    1151
    934
    I use these things a lot and I own many different brands. Starret though, is the worst and most inconsistent. My Mitutoyo snap gauges are superior in every way. Since feel is what accuracy is all about with these and my Mits are really smooth, my readings are consistent and that gives me confidence when using them.
  9. Likes hotbluechips, dian liked this post
  10. #8
    Jul 2006
    Hillsboro, New Hampshire
    4,527
    996
    3096
    Quote Originally Posted by steve-l View Post
    I'll second the Mitutoyos over the Starretts. Much smoother, more repeatable readings.
  11. Likes AlexO liked this post
  12. #9
    May 2010
    Denmark
    17,236
    3563
    10288
    I've often wondered why the non movable part isn't cylindrical at the end instead of rounded. Would eliminate almost all the need for "wiggle".
  13. #10
    Sep 2004
    RSA
    1,107
    394
    278
    Quote Originally Posted by Gordon B. Clarke View Post
    I don't think it would. It would replace one variable with another. There are bore gages with cylindrical ends - they don't work any better.
  14. #11
    May 2017
    FINLAND
    1,128
    298
    532
    How would you use that?
  15. #12
    Mar 2017
    CHINA
    1,813
    1127
    Quote Originally Posted by MattiJ View Post
    With a full set of micrometers that have rounded anvils of different radii
    Or you could trig it out. That'd be convenient ....
  16. #13
    May 2017
    FINLAND
    1,128
    298
    532
    Quote Originally Posted by SeaMoss View Post
    I can see some problems already before you get the telescope out of the hole..
  17. #14
    Mar 2017
    CHINA
    1,813
    1127
    Yeah, I don't think Gordon is going to sell very many of his new invention.
    Gotta admit it's innovative tho
  18. Likes tdmidget liked this post
  19. #15
    May 2010
    Denmark
    17,236
    3563
    10288
    When I thought of and patented my thread pitch diameter inserts/system some still don't believe it does what it does. They don't look like this but here's the principle:
    http://www.f-m-s.dk/6D3%20FMS%20Thre...0Principle.htm
    The range of pitch one pair of inserts covers (fx 2 - 4 mm / 13 - 6 TPI) plus the variation in flank angle (50º - 80º) is pretty damn amazing.
    Even measuring an internal M6 or 1/4" is no problem.
    As to what I meant re telescope gauges then:
    Going by "It's always been done like that" kinda brakes innovation. I'm not saying my idea re telescopic gauges would work but maybe worth a try?
  20. #16
    May 2005
    AZ
    2,174
    185
    728
    To the OP: The difference lies in the minimum range; with two telescoping sections, the smallest gage can measure down to 5/16" in the 579 set, vs. 1/2". Also, with two telescoping arms, you can move the handle sideways in both directions; if the need arises in some situation where you need to measure an offset bore down inside another bore, it's an additional element of convenience.
    I have a set of Yuasa telescoping bore gages that I really like, probably late 70's-early 80's made in Japan, pretty smooth, and longer handles than most of the other standard telescoping gages. Nice satin chrome finish as well. EBay find a few years back.
    I can't imagine how this would work; if I understand the concept, you would have a cylindrical end face as a contact for the inside of a cylindrical bore instead of a point contact of the standard spherical end? You'd get proportionally different results for every different size bore within the range of a given gage. Am I missing something here?
  21. Likes tdmidget liked this post
  22. #17
    May 2010
    Denmark
    17,236
    3563
    10288
    Quote Originally Posted by specfab View Post
    I don't know if you're missing something or not. Forget the word "cylidrical" and think of a small radius running the length of one contact surface instead of two rounded contact surfaces.
    With two rounded contact surfaces wiggle is needed to get the "smallest reading". If one contact point is as I showed in the sketch then this would IMO stabilize the gauge and need as good as no wiggle.
    I've done this with inserts I had made and it worked really well. If necessary I can take pictures of the inserts I used. They can't though be used for a internal diameters/recesses less than 35mm/1.375".
    With a telescoping gauge I can imagine much smaller diameters possible.
    If it helps try thinking about how the internal measurement jaws of a caliper works. Not much wiggle needed. They can't measure deep though.
  23. #18
    May 2017
    FINLAND
    1,128
    298
    532
    I think I'm getting what you are after. One end of the telescope stick would have flat (with line contact) on the bore and it would set the stick perpendicular to the bore axis automaqically. First problem that I see with that is slipping the stick out of the hole without disturbing the setting. If one end has non-point contact you can't tilt the stick at all but you have to pull it out exactly perpendicular like it was locked.
    You mention "wiggling around" the telescopic stick for minimum but that's not how these things are normally used in US?
  24. #19
    May 2005
    AZ
    2,174
    185
    728
    OK, now I have the picture. That would likely require a fixed arm (only) for the line contact side, to maintain the axis alignment of the line contact to the handle, and it would be sensitive to both axes of in-plane tilt. The line contact section would likely need to have a bit of length to make it worthwhile, IMO. As MattiJ notes, getting it out without disturbing the result would be a challenge; probably an opportunity for making an accessory to hold the gage centered and square during measurement and retraction.
  25. #20
    Mar 2017
    CHINA
    1,813
    1127
    The way he drew it is not possible. It's got to roll in the other axis, too. If you made the high spot on the leg into a point it could work, but that's basically what they are now. And a point would dig in to softer materials, where a section of a sphere (what they are now) slides across the surface. No advantage, lots of disadvantage.
