First off I am new to this forum and hope I will learn a lot from it an the people involved. I have just started as a calibration technician so I am green on many things. My question is with a Mitutoyo 126-902 thread micrometer that i need to calibrate. Much of the information I have come across does not going in detail of what is needed to calibrated it to the OEM tolerance. So far I have been led to believe that i can calibrate it using a Davis "Roll check" model RC-755 or at least the .0625 wires. I tried with no luck. I have easy access to a Van Kuren thread wire set. I can not easily locate a procedure so I am currently trying multiple things to see if it works. I unfortunately do not have a master thread plug that i can use so the easy way is out of the question. Does anyone have any advice on how i can correctly calibrate the micrometer?
Thank you ahead of time.
