Much too will be about tools from "the good old days" when everything apparently was better.
Well of course it was when looking back from now because all of the real rubbish and most of the so-so kit got dumped years ago.
Pretty much all of the older equipment you see on the market now is mid to high end gear. Often filtered by years of use by skilled toolmakers and the like who needed decent, reliable equipment to keep making money by turning a good nob in in reasonable time. Unaffordable new on apprentice, just starting out and machine operator with aspirations money. Heck my first dial gauge was a Unique, about thruppence three farthing used down from 5 bob, or maybe 'alf a crown, new. My first micrometer was a mail order no-name of somewhat dubious and uneven accuracy for probably the price of a couple of pints. Which is about when I learned not to trust mail order. Nice case tho'. Still have them for nostalgia. To be fair, the Unique is remarkably accurate considering its basically a needle in a folded sheet of embossed tin. Seen "looks the proper part but worse performance" for proper money.
Have maybe £500 - £ 600 in conventional measurement gear about the place these days. Lord knows what it would have cost new from the shop but its all either very good used or new old stock when bought :-
Micrometers full sets 1" to 12" and 25 mm to 325 mm by Moore & Wright, Starrett, Tesa a few duplicates, both styes of M&W 2", a tube mike and Mitutoyo multi anvil 1" to 6" which never gets used.
Verniers:- daily drivers are full set heavy duty M&W, with the long vernier scale, up to 2 ft and a couple of decent brand ordinary 6" ones.
Dial calipers :- Mitutoyo 8" and 200 mm, M&W 6" and 150 mm.
Internal micrometers to 6" and 150 mm, 3 off one Starrett, two M&W not sure which is which without looking.
One full set of M&W telescoping gauges, one half set and all the small bore companion set. Plus a few extra odd ones.
Depth micrometer sets:- M&W 0 to 6", Starrett 0 to 150, B&S 0 to 2". Also 2 Starrett 12"-300 mm depth vernier sets one with both scales one with only the long one plus a couple of no name 8" 200 mm ones for ruff and loaner jobs.
Maybe 10 or 12 dial gauges, all good makes. Lever and plunger covering pretty much all the normal sensitivities. One day I need to do a proper census.
Both styles of M&W bevel protractors with the accessory long rulers and a half decent version of the weird quadrant one got for one job and, thankfully, returned to store. Starrett combination square, like what everyone has, of course.
Height gauges one Mitutoyo 300 mm vernier, APE Microball in 300 mm and 12".
Only digital gauge I have is a supermarket special. Unused since the battery died and un-missed. Unless you count three sets of nano-metre sensitive Heidenhain probes and readouts which bumps up the investment a bit more. As do metric & imperial new old stock sets of Weber gauge blocks. Various other assorted useful items hoovered up at nearly know money when offered by the unknowing before throwing away. Even with these still probably less than £1,000 in there.
Should really thin the list via E-Bay but the return hardly seems worth the hassle. Sometimes loaner gear is handy.
Wouldn't replace it all if I lost the lot but ...
Clive
