35 Dodge
- Jan 15, 2008
- Claremont, NH
I would like to know what the correct method of checking true positon of 6 equaly spaced holes that are drilled radial. The first hole is centered on the print the second hole is 60° basic to it. There is a basic length location of .225 from Datum B which is a plane. The hole size is .025 +/-.002. the feature control frame states true position, with a cylindrical tolerance zone, .035 tolerance, to Datums [A]. Other than using a CMM how could I go about inspecting these features. What I have is gauge pins a vision system and a comparator to use.
