A level is a go no go Gage not a measuring device.
it is a measuring device,it measures angles relative to level.
US Federal Spec A-A-50685:
1. COMMERCIAL ITEM DESCRIPTION LEVEL, PRECISION MASTER, SINGLE FACE
The General Services Administration has authorized the use of this commercial item description as a replacement for Type IX, class 1, single face, precision master level in superseded specification GGG-L-211C.
1.1 This commercial item description covers a single face, precision master level used to calibrate other levels.
2. REQUIREMENTS.
2.1 The item shall be made of steel or close grain cast iron of a design to preclude warping or deflection due to temperature change. It shall also consist of a single faced stock, one adjustable level vial, one f~ed cross test vial, a vial holder, a cover and a case. The vial shall have a cover or top plate of heavy nonferrous metal or plastic to shield vials from heat of operator's hand. It shall be 15 inches long and have vial accuracy of 0.0005 inches per foot of single faced stock. Concavity and convexity of single faced stock shall not exceed 0.0002 inches per foot. The vial shall be a glass tube with a vial
sensitivity of 10 seconds, maximum. The vial shall have no less than three
auxiliary lines, permanently marked, spaced l/10 inch apart on both sides of both bubble defining lines. The angular value of these lines in either degrees or inches per foot shall be permanently marked on the level.
2.2 The level, including all parts and accessories, shall be free from burrs, rust, external sharp or rough edges, imperfections, and any other defects which may impair serviceability, durability, appearance, or operational performance.
3. QUALITY ASSURANCE.
3.1 ~ The contractor shall certify that the product offered meets the salient characteristics of this description and that the product conforms to the producer's own drawings, specifications, standards and quality assurance practices, and is the same product offered for sale in the commercial marketplace. The government reserves the right to require proof of
such conformance prior to first delivery and thereafter as maybe otherwise provided for under the provisions of the contract.
It lives in this pile of GSA specs....
Document Number Document Title FSC P reparing Activity Date Superseded By Document Status
GGG-B-461A Blocks, Step, Machinists' 5220 AR 17-Aug-1966 Active
GGG-G-61 Gages, Plug and Ring, Plain and Thread (Inactive) 5220 AR 23-Aug-1932 Active
GGG-P-61A(2) Parallels; Steel and Cast-Iron, Precision-Ground 5220 84 6-Jul-1966 Active
GGG-P-441A Plates, Angle, Adjustable and Solid 5220 PA 9-Apr-1965 Active
GGG-P-453A(1) Plate, Surface, Cast Iron 5220 99 8-Apr-1965 Active
GGG-P-463C(1) Plate, Surface, (Granite) (Inch and Metric) 5220 NBS 10-Sep-1973 Active
GGG-B-121B Bar, Sine; Plate Sine (and Fixtures) 5220 AR 4-Jun-1964 Active
A-A-58089 Comparator, Bench Type, Electronically Amplified 5220 84 10-Dec-1996 Active
A-A-59120 Gauge, Surface Plate Flatness Checking 5220 84 22-Sep-1997 Active
A-A-50767 Analyzer, Surface Finish 5220 IS 15-Aug-1983 Active
A-A-50685 Level, Precision Master, Single Face 5220 IS 8-Jul-1989 Active
A-A-59572 Gage, Comparator, Electric 5220 84 29-Mar-2004 Active
