when should you replace your thread ring sets? seems easy right? not so with my company.
I have adjustable thread ring gages that go out to be calibrated. (I don't have the expertise or all the master thread plugs to calibrate them. Some come back 'PASS- starting to bell' and 'adjusted 3 times: need to replace'.
Boss states 'pass-bell' still within spec no need to replace they just want more money.
Boss states 'adjusted 3 times' have them adjust it until it fails they just want more money.
Just wondering what do others do with the belling effect on the gages and the calibration vendor stating that after adjusting the thread ring gages 3 times it should be replaced 'due to maybe it will start to bell'.
My tolerances usually are +/- .005" sometimes down to .001" and the class of these gages are class X. I think the thread master set plugs they set to are made to class W if that helps. The vendor is national lab certified so I believe them but most of the time I deal with the sales agent and not the QC head.
Any insight would be great and thanks from the noob.
