I contacted Monarch about the gaskets and seals, and surprisingly, they have all the gaskets.
The seal for the reverse shaft turns out to be a Garlock 1x1.75 inch series, surprising since the reverse shaft is 25 mm. I ordered the seal along with the gaskets since I didn't know what it was, but knowing the size now, the SKF green seal type for about $3 would be satisfactory. Monarch price was $14.
The total price for all this was about $200, but the amount of effort it will save me makes it worth it.
Footnote, I am aware the rear bearing cap gasket is missing the hole for the oil drain return. I assume their subcontractor messed up the die. I will contact Monarch about this. Easy fix, knowing that it is missing.
