Hello everyone,
I ran across this Monarch 12CK on CL, and took look at it. It's been abused, but is it worth saving. If so, what value would you put on it?
It has two handles that were broke and welded back on, poorly I might add.
I think there is little to no oil in the headstock. http://www.practicalmachinist.com/vb/images/smilies/eek.gif
The ID tag looks like it was painted black, then rubbed with 60 grit sand paper to reveal it's numbers, nearly impossible to read.
The sight window(???)to the right of the ID tag has a hole in it. View attachment 180961
There is a chunk of housing missing above the Upper compound lever. View attachment 180968
There is a good bit of play in the Apron handwheel, before the Apron moves. Can this be adjusted?
The Crossfeed handle has a good bit of play, as well.
The Crossfeed way is very scored. View attachment 180969
The Compound rest has been run into the chuck many times.
The Bed way has a score in it about 18" long. I have a picture, but you can't see the score due to flash glare. Didn't know it at the time.
For the most part, it has sat in the current owner's garage/shop for about 5 years with little use. But it has been used (with the little to no oil in the headstock.
I have a few more pictures, if needed.
Tell me what you think.
Thanks!
Duane
Thanks!
Duane
