Light Hammer
- Aug 27, 2015
Hello all,
First post so please forgive any ignorance
In another life I was a toolmaker who worked for a company called Talon in Gastonia, NC. The company originated in Meadville, PA. I spent most of my time at Talon running a surface grinder. After the company folded I became a Police Officer and continue to be so today. I never really got the machining bug out of my system though. Several years ago, I purchased a Bridgeport mill along with some support tooling which I have at my home shop. I've always wanted a lathe however I successfully resisted the urge to purchase an import. I've looked for a nice piece of American iron for years and now, I think I've found it.
I know it's a Monarch. The name plate reads: 16" with a serial number of 37603. The manufacture date appears to read 11-1-1952. The current owner states it's a "60 series." After reading this forum and looking at numerous pictures, I believe that he is correct. The machine is in pretty good shape, or at least it appears to be. I'm going tomorrow to thoroughly inspect it. The things I know are as follows:
- It's powered by a 15hp motor
- It's currently under power and used on an irregular basis in a small job shop
- It's super heavy
- It runs very quietly, shifts through the gears with minimal effort and makes no unusual sounds
- It's super heavy
- The ways are not scored or damaged
- It's super heavy
- The current owner states it will hold .0005 however I haven't checked any of his work
- Did I mention its really, really heavy?
Ok, so I'll inspect it tomorrow and post my findings here. My initial question concerns powering it at my shop. I do not have 3 phase power. I run my mill with a VFD. I'm told I can run this lathe with a 30 hp VFD fed with single phase power. Is this accurate? Also from what I've read, I'll have to size the circuit at 125% of the VFD's rated input (which appears to be around 90 amps) meaning I'll have to install a ~115 amp circuit, if I keep the 15 hp motor. Another source states that I can install a smaller motor (5 - 7.5 hp) and run a smaller, appropriately sized drive as I highly doubt I'll ever have need of 15 available hp. This route seems advantageous as I'd be running a brand new motor in place of the 63 year old motor currently installed. Also, running a VFD would allow me to bypass the antiquated starter/wiring/fuse/whatever else is in the belly of this beast current setup. As far as a new smaller motor goes, I think the cost of the motor itself would be offset by the reduced cost of the VFD making the change to a smaller motor a little less financially straining.
If (that's a big if) this lathe works out, do you guys think I'm on the correct train of thought as far as powering the machine goes?
- It's super heavy
- It's super heavy
- It's super heavy
