Results 1 to 9 of 9
    Reeltor is offline Cast Iron
    Jun 2009
    Lawrenceville, GA USA
    306
    Default 16CW running backwards
    I have just powered up my 16CW for the first time. Monarch said that Motor pulley and drive pulley at clutch should run clockwise (when looking directly at shaft). The chuck is running backwards . Can anyone with a "C" series check the correct rotation of the motor and drive pulley?
    Mike
    johnoder's Avatar
    johnoder is offline Diamond
    Jul 2004
    Houston, TX USA
    18,600
    Here is my 16 CW with the cover off:
    There are three shafts and then the spindle
    For the spindle to turn CCW looking at the chuck, the input shaft (and clutch pulley) have to turn the other way looking at the chuck end of that first shaft.
    John Oder
    docwilson is offline Cast Iron
    Feb 2004
    Macon, MO USA
    281
    If you look at the clutch with the clutch cover off as in the picture below, the clutch should turn counterclockwise when the lathe is normally running forward . If the lathe is running in the reverse mode, the clutch should be turning clockwise. If your lathe is opposite of this, you need to switch any two of your 3 phase input leads to reverse the rotation of your motor.
    Jun 2009
    306
    Default Looking at wrong end of shaft
    Quote Originally Posted by johnoder View Post
    John Oder
    John I am dense and it may take me awhile to make sense of it. If I understand you, I am looking at the wrong end of the pulley shaft, (at the clutch) to determine correct rotation. So reversing two phases on the motor will correct the problem making this end of the shaft turn CCW---the chuck end of the shaft will CW and the chuck will turn correctly; CCW.
    This lathe does have the optional reverse lever, (that doesn't appear to do anything) Is the reverse lever supposed to control the spindle direction?
    Thanks for your help
    Mike
    beckley23 is offline Titanium
    Feb 2003
    Louisville, KY, USA
    2,896
    If you're referring to the apron mounted reverse lever, that is for reversing the leadscrew and feeds. Don't reverse the feeds with the spindle running, you will really hammer the reverse gears in the headstock, jog the spindle instead.
    Harry
    Jun 2009
    306
    Default Reverse lever
    Quote Originally Posted by beckley23 View Post
    Harry
    Harry, the reverse lever I'm talking about is on the headstock between the two sets of speed adjusting levers.
    Jun 2009
    306
    Quote Originally Posted by docwilson View Post
    Thanks Doc, I was trying to re-size my photo of the Clutch end while you were posting this (don't think we need 31 inch photos ). I'll put the two 3 phase leads back where they were.
    Mike
    johnoder's Avatar
    Jul 2004
    Houston, TX USA
    18,600
    Just the direction of feed rod and lead screw, which I think Harry already said.
    Some had this operational from right end of apron, but not the CW 16
    John Oder
    Jun 2009
    306
    Default Corrected wiring
    Just wanted to say thanks to all who are helping this noob get this lathe up and running. Monarch responded this morning with same recommendation. Switched the leads this morning and lathe is running in correct direction.
    Now my feeds are not working; I'll start a new thread
    thanks again.
    Mike
