krittenhouse
- Sep 12, 2016
In search of some information on my 1951 Monarch 16" lathe, serial number 33255. I am having a problem with the gear oiler located inside of the resivoir. I ran the machine for about 20 minutes with the cover off and didn't see a single drop of oil come out of any of the lines so, i pulled the lines off the pump and turned the machine on. There was a very small amount of oil that started to flow out after about 2 minutes. Is this a normal rate of flow or should there be a consistent drip onto the gears?
