Dear All,
I don't usually seek help on forums but I think I can really benefit from the experts here.
I bought my 10EE earlier this year, worked great, very powerful. It had problems maintaining speed below 300rpm, which is an issue when I'm parting with HSS tool, but I managed.
A few weeks ago, it popped the 3A fuse. I was under the gun to finish a part so I jumped the fuse (I know I know....). That actually brought the machine back to life. I was half way through an aluminum part before it stopped working again.
Deservingly, now I have much bigger issues. When I turn on the power, it warms up, I can hear the fan go on, and after a while the machine lights turn on. Great.
When I hit the green lighted button, the Power Relay (PC) engages, but disengages as soon as I let go of the green button. So I took the time to learn the system and the troubleshooting begun:
1. Noticed the Field Loss Relay (FL) does not engage. I removed it, serviced it, made sure it works. It only took 0.5V to energize the coil to engage. Not sure if this is normal but it works well. Reinstalled back into machine, didn't fix the problem.
2. Followed and noticed that wire 18 on the FL coil connects to the contacts on the Anti Plugging Relay (AP). Removed AP, inspected, found a broken wire (a soft braided one soldered onto the coil switch). Happily replaced the wire, serviced the relay, made sure it works (took 36V to energize coil), reinstalled, didn't fix it.
3. Found 2 blown diodes in the module, both Rec 3. Replaced them with 1N4007, those are what I have on hand. Replaced both, ensured correct direction. Reinstalled, didn't fix the problem.
At this point, amongst the 50 other things I poked around with, I managed to get PC to engage and STAY engaged, for about 10 to 20 seconds, then it will disengage again. During this time, strangely, the safety interlock solenoid will drive the piston back and forth - extend, retract, extend, retract, at about 2 seconds intervals.
4. Checked the temperature sensor inside the tube enclosure, and it provides continuity between the 2 poles.
5. Checked voltage between terminals 5 and 18 on FL's coil. When I hit the green button, the voltage goes up to about 0.5V, and holds the PC engaged, but the voltage then drops to 0 after 10~20 seconds, and PC consequently disengages again.
Does anyone have any ideas what's happening here?
Thank you so much for taking the time and reading this boring post....
Howi
Howi
