Hi all;
I hope another 10EE paperweight post does not bore everyone. I have looked through previous like posts and have not found answers. I have a 1951 10EE with reliance VS drive. Moving headstock lever does not actuate either forward or reverse relays. When the lever is moved and the appropriate relay is mechanically thrown the lathe functions and is able to hold the relay closed on it's own. I have checked the continuity of the C1-C3 and C2-C3 in the control box and when the headstock lever is shifted both tests produce ~ 1/2 ohm. Continutity of C1 (forward) and C2(reverse) to their appropriate solenoid is good. The solenoid resistances for forward and reverse relays is 850 ohms and 900 ohms respectively. Both solenoids output lead to the AP relay. The impedance of the AP relay's solenoid is ~ 4000 ohms. I have cleaned all relay contacts and checked continuity. There are 3 resistors mounted from the front of the control board. Two of them have the appropriate resistance 2100 ohms and 1600 ohms. The third resister is ~29000 ohms and I believe it should be 1600. I have measured the excitation voltage across E1 and E2 in the control box and found it to be 120V. Are the solenoid resistances in line. What wattage resistor are those wire round components found in the box. Any help/suggestions would be greatly appreciated.
