I bought a 1953 10EE to fix up hopefully not rebuild to give to my dad as a retirement gift he has in Tool & Die for fifty years now and has a small hobby shop at home a Bridgeport mill Taft Peirce surface grinder that I rebuilt small Hardinge horizontal mill and a crappy old Rockwell lathe.
I have read some of the post here and see that many of you are very knowledgeable on the old Monarchs so right now I have 1,500 in the lathe a 7.5HP
inverter motor and a 15HP drive set up for single phase he only has a 5hp rotary phase converter I know a lot of you believe in keeping the DC motor
but this machine has the WIaD and the person I bought the lathe from had already pulled that out and took all the wires off. I was told it was not working and I do not have enough electronics background to know what I'm doing with it I do have all the electronics on a skid. So I have
taken the back gear off and made adapter and mounted on the new 7.5HP invertor motor I have the oversized VFD drive so I can run on single phase
and a speed pot so I can keep original speed control knob. I believe iron is in good condition I measured thickness of back flat way and all checks
full length of bed are same within .0007 The only check I did on front v way was removed chuck so I could move carriage till the front Gib bearing was at 1/2 inch from font end of bed could barely turn bearing with fingers then move carriage toward tailstock with my finger on bearing got about 3 inch before I could keep bearing from turning easily with finger I did not find any where along way as I moved to tail stock that I could not get the bearing to where I could turn it with fingers when I put a .001 plastic shim in between bearing and way is there any other checks for bed
wear I should do. Cross slide lead screw & nut is worn when all cross slide is all the back toward operator only .003 back lash when in around normal work envelope we have .018 back lash is this a monarch only item or are there good after market ones available. I'm going to pull sadle and replace all Bijur meter units and lines. replace sight glass they are hard to see through and change all oils replace all felt wippers. the quill on tail stock looks good clean and no scaring. Is there anything else I should look at or do remember this is just a hobby machine. I have a 5C collet chuck 6inch 3 Jaw with removible top jaws and face plate for machine anything else he will have to get for himself. Hopefully I will be able to get much need advise for some of you fine folks her as I get more into this machine and when its done we can shoot the old Rockwell to put it out of our misery.
