I just rebuild my apron and install new bearing and lubrication system. I installed the carriage, no problem. Now I just installed the apron and when I tight the two assemblies together with the 8 bolts on top of the carriage the cross slide screw get lock by the two gear meshing together (the gear from the apron to feed the cross slide with the gear from the cross slide dial small gear). I checked the distance and it is perfect, I thought maybe I installed the gear backwards, I double checked that already. It seems like if would need a gasket but I don't remember taking off a gasket. I checked the parts manual and it does not show a gasket either. If I loss the bolts it works okay but now I developed a gap in between the apron and carriage, also if I remember correctly those were very tight when I took them apart. Please let me know if you have any experience with it.
Thanks.
Thanks.
