THE 1965 10" EE MONARCH LATHE IN QUESTION HAS BEEN RUNNING FOR QUITE SOMETIME WITH NO PROBLEMS. RECENTLY, THE LATHE STARTED ACTING UP BY TRIPPING THE CONTROLS AROUND 60 RPMs. ALSO, THE SPEED OF THE SPINDLE DOES NOT MATCH THE ROTATION OF THE SPEED CONTROL KNOB. WE COMPARED BOTH LATHES, WE HAVE TWO THAT ARE THE EXACT SAME, AND IT TAKES SMALL TURNS OF THE SPEED CONTROL KNOB, ON THE LATHE THAT WORKS, FOR THE SPINDLE TO SPEED UP WHEREAS ON THE LATHE THAT DOES NOT WORK, IT TAKES MORE TURNS TO INCREASE THE SPINDLE SPEED TO THE POINT WHERE THE SYSTEM TRIPS. WHILE TROUBLESHOOTING THE LATHE IN QUESTION, WE FOUND THAT INCREASING THE SPINDLE SPEED, BEFORE THE TRIP POINT, WOULD CAUSE THE NORMALLY CLOSED AP RELAY TO CHATTER. THE LARGER THE SPEED INCREASE, THE LOUDER THE CHATTER ON THE AP RELAY, BUT THE CHATTER IS NOT CONSTANT WHEN THIS POINT IS MET. THE CHATTER GOES IN AND OUT UNTIL THE TRIP POINT IS REACHED. WE ALSO FOUND THAT WHEN A CERTAIN POINT WAS REACHED ON THE SPEED CONTROL KNOB, OR A CERTAIN SPEED WAS MET, THE POWER CONTACTOR AND THE DYNAMIC BRAKE CONTACTOR CONTACTS BEGAN TO CHATTER. ONCE THE SPEED CONTROL KNOB IS TURNED PAST THIS POINT, THE FL RELAY CONTACTS OPEN SHUTTING DOWN THE CONTROLS TO THE LATHE. THIS HAPPENS IN FORWARD AND REVERSE MOTION. ONCE THE SYSTEM CONTROLS TRIP OFF, THE DRUM SWITCH CAN BE PLACED BACK TO THE NEUTRAL POSITION WHERE THE SYSTEM RESETS THE CONTROLS. NO FUSES ARE BLOWING BECAUSE THE DRUM SWITCH CAN BE PLACED IN EITHER THE FORWARD OF REVERSE POSITION, AFTER RESET, AND THE SYSTEM RUNS UNTIL THE TRIP POINT IS REACHED AGAIN. ANY SUGGESTIONS AS TO WHAT COULD BE THE CAUSE OF MALFUNCTION?
