The real Leigh
- Nov 23, 2005
- Maryland
The phasing of the filament voltage with respect to the plate voltage is significant in prolonging the life of the tube. This post presents a method of properly setting that phase relationship in the event that the transformer wiring has been changed. Some explanatory notes appear at the end.
The pinout diagram on the datasheet makes this relationship obvious:
The intent is for anode current to flow through the F- pin. If the phasing is wrong, anode current will flow through the F+ pin, possibly causing excessive heating and premature failure.
WARNING: Hazardous (potentially lethal) voltages exist in this system. If you're not familiar with proper troubleshooting techniques and safety precautions for working on high-voltage control systems, do not attempt to do so.
This procedure requires use of a dual-channel triggered oscilloscope with two 10x divider probes. The probes should be rated for 600 volts peak input. Almost any oscilloscope can be used, since the signal is only 60 Hz.
Because of the high voltage present on the C16J anode during operation, a special 10:1 voltage divider must be constructed for use between the oscilloscope probe and the tube, as shown in the diagram:
The following instructions assume a basic knowledge of oscilloscope operation.
1) Turn off all power to the lathe.
2) Set the 'scope as follows:
....Channel 1: 10 volts per division, AC coupled
....Channel 2: 0.5 volts per division, AC coupled
....Vertical mode: two-channel chopped
....Trigger: channel 1, positive slope, automatic mode
....Sweep speed: 5 milliseconds per division
3) Connect the divider network and 'scope probes as shown.
4) Set the lathe speed control to zero.
5) After confirming all correct connections, turn on power to the lathe.
6) Engage the controls for forward operation.
7) Adjust the vertical position controls so you see two waveforms, one above the other.
8) The waveforms should be in phase, i.e. the rising edges of the two should be inline.
9) If one waveform is inverted relative to the other, reverse the filament transformer connections.
Power the lathe down.
Repeat the above tests for the other C16J.
Notes:
1) The 470K resistors are spec'd at 5 watts due to voltage ratings. Lower power resistors have lower voltage ratings.
2) Chassis is used as the oscilloscope common connection for safety reasons. The probe shield on most 'scopes connects directly to AC power line safety ground. The lathe chassis is connected to control circuit common (line GA2) via a 0.1 mfd capacitor. This connection is adequate for our purposes.
3) The phase of F+ is measured WRT filament center tap (GA2) since this permits use of chassis for the channel 2 ground connection. That phasing is identical to the phasing across the entire winding (F+ to F-).
- Leigh
Notes:
- Leigh
