idler pulley clarification
Not only do I need the bearings but I also need the idlers wheels and brackets too. Both assemblies are completely missing from my 10ee. Thanks
I think I still have the idler wheels and bracket on a 10EE I'm parting out. Its at my warehouse, probably won't be there until Wednesday.
idlers
Looking forward to hearing from you. Thanks
I did locate the Monarch idler, its the diecast version with decent bearings, $35.00
Are there two?
There are two belt idlers. One towards the back of the lathe that travels in a t-slot and another toward the front of the lathe on a bracket. How can I get in touch with you to arrange the sale of these parts? Please send an email. Thanks
Sent you a P M regarding the idlers
 Originally Posted by JohnnyJohnsoninWI
...A bit more information. The supplier is Noma IKS Corporation, 1555 W. Rosecrans Ave., Gardena, CA 90249-3027, www.iksbearing.com/index.html. I ordered two #88503 and four #87504 bearings for the three idler pulleys. They cost $9 each and charged $7.73 for shipping to WI.
John,
Question about the feed belt idler bearings.
The old ones I took out (may have been replaced once already) are 87503, and you tried 88503.
Looks like 88503 has two sides extended inner race and double seals:
http://iksbearing.thomasnet.com/item...=10&assetid=g2
And looks like 87503 has one side extended inner and a shield and seal:
http://iksbearing.thomasnet.com/item...=prod&filter=0
Thinking I should order the ones I removed, and there is a difference in our idler pulleys, or am I missing something?
Grigg
 Originally Posted by Sean Myers
You can get them for around $6 from accurate bearing. japanese made too.
Agreed. The spindle belt tensioners take a pair of Accurate Bearings' 87504, and the feed belt tensioner takes a pair of 87503.
Sean
March 2010, Accurate sells the Japanese IKS brand 87504s for $12 each.
- You may not post replies
- You may not edit your posts
Forum Rules
