lectrician1
Hot Rolled
- Mar 6, 2012
- Las Vegas
there are two spring loaded studs on the back on my cross slide to provide easy removal of the cross slide way cover.
I am looking to install a DRO and i need to attach the scale to that way cover. i would like to remove the spring loaded studs and tap the existing hole for a stronger mechanical bond.
Question: How do i remove those spring loaded studs?
There was a set screw in the side of the crosslide which i removed but i can't figure how to get the studs out
thanks for your help
