gernoff
Hot Rolled
- Mar 19, 2011
- Great Falls, Montana
Measuring on the D1-3 spindle taper I am getting very near the 50 millionths runout (damn its fun to say that) expected, when I do a torque test with the trusty broom handle I am seeing about 2/10 slop in the spindle. The spindle does not spring back to center.
Now...... If I apply to torque at the rear of the spindle I am getting about the same readings.
If the rear bearing was shot should I expect this 2-3 tenths reading at the spindle nose?
My thoughts are that if it were the forward bearing set, I would see less slop when applying force at the rear of the spindle vs. the front (wishful thinking?).
Can the rear bearing be replaced without removing the spindle? I would like to start by replacing the rear bearing and see if the spindle slop is fixed.
I get the impression from other posts that the spindle and front set can generally be removed without damage if one is careful.
