macona
- Jun 20, 2006
- Beaverton, OR
Decided to tackle the bent feed rod today. Wobbles pretty good like. My guess some time in the past someone lifted the lathe with a sling and squished the feed rod.
Pulled off the outboard support and knocked out the drive pin in the feed clutch and slid it out. Simpler than I expected.
Question is the keyway down the length is only .154" wide. This machine had been rebuilt at one time by some company called Hademann-Nielsen of LA so maybe a new rod was machined to make up for the key wear in the worm gear?
I was going to use some pre-keyed stock to make a new shaft but thats out of the question now. Do you think I can get away with using some 3/4" drill rod to replace it? The rod is alost exactly 3' long.
Also should the taper pin in the feed clutch be steel or something softer?
