CreeCustomGuns
- Jul 5, 2017
I have a 1945 10EE round dial that i now have powered up. All if good except for the cross-feed. The cross-feed is constantly linked to the power feed. If I pull round push/pull that is just below the lever for the cross-feed drive, the cross-feed engages and begins to move. I have taken the tension cap off of the clutch and it still does not disengage. I have tried all that I know of doing and it will not disengage. I have noticed that block-like assembly in the center of the clutch assembly has a lot more in and out play in it than the carriage-feed clutch.
Any ideas on how to fix this?
Thank you!
Thank you!
