Results 1 to 5 of 5
    beckley23 is offline Titanium
    Feb 2003
    Louisville, KY, USA
    2,896
    Default EE Taper Attachment Covers
    Looking for a set of covers for the TA. While I'm searching, might as well look for the TA vernier also, I know it's a real long shot.
    Harry
    PaulM is offline Hot Rolled
    Feb 2007
    upton ma
    954
    HI Harry,
    I assume you know Miller Machine & Fabrication makes repros for $66/set.
    I have not done it yet but my plan for a cheaper solution is to cut up an aluminum 1/2 sheet pan - coust should be about $15 and it may yield 2 sets, of course it wont look original if that matters.
    Paul
    Feb 2003
    Louisville, KY, USA
    2,896
    I'm aware of Miller, and an email was sent earlier about mounting.
    Harry
    Knguyen is offline Cast Iron
    Jun 2003
    Bergen, NJ.
    443
    I have done just what Paul said. The cover was made from aluminum baking pan. This one had almost identical rounded corners and also a non-sticking coating. Functional like the real ones
    Feb 2003
    Louisville, KY, USA
    2,896
    I'll check into the baking pan idea. Thanks
    Harry
