whateg0
- Mar 24, 2009
- Wichita, KS
This may be a dumb question, but when the ELSR is switched to LH, which way does the spindle turn when the control rod/lever is pushed down? I am working on wiring in a VFD and I was hoping that the wires could just be pulled from the ELSR and used to drive the fwd and rev on the VFD. So far, from my reading of the schematics I've found online and the way the switches are wired in the ELSR, it looks like the spindle rotates forward when the ELSR is set to RH and the lever is pushed down or the ELSR is set to LH and the lever is pushed up. Is that right? And normal? I suspect so, since that lets the ramps that return the control rod to center work the same way, but it seems counter-intuitive to go up to turn the spindle forward.
Dave
Dave
