fuse protection for monarch 10ee
Industrial Electric Feedrail Fusible Connector Plug Box Fuse 22V 3-Phase 3-Pole | eBay
this has fuses at 15amp per line, any opinions,, i was told 30 amp fuses, but wouldnt this protect the lines even better...
Arguably 'yes', but it isn't actually 'right'.
You might even 'get way with it' for a long time. I did much of my testing of nominal 12+ FLA 3 HP "large frame" MG-era Reliance motor and Eurotherm/Parker-SSD DC Drive (24 A input, nominal) off a 15A Square D "QO" breaker with no drama.
Meanwhile 'back at the load center', it is generally preferable - read "cheaper" - that an easily reset-able dedicated-load breaker trip rather than one or more single-use-cycle cartridge fuse blows.
And, of course, when you 'get it right', NEITHER have to do.
Your budget. Your choice.
properly sized fuses CAN provide BETTER protection than a circuit breaker for just about any load situation or device but Why. Wiring needs Nominal protection. Some semiconductors will benefit from fast blow fuses. Motors want their own type of protection which can be fuses. IOW it's complicated if you want it to be.
Assuming that we're talking about a motor/generator (MG) 10EE, 15A fuses will not work. During startup the MG draws about 100A for the first second or so. That's enough to pop a 15 or 20A, time delay fuse. As long as the internal wiring of the machine, from the disconnect to the MG, is still at the original 10 gauge wire size, 30A fuses are fine.
It's normal industrial practice to have a fused disconnect at the machine. You would have to check with a local electrician to see what's required by local code.
Cal
+1 The input has to drive the starting load of the 3-Phase AC Motor of the 'Motor-Generator'. That has slightly higher starting load/inrush than comparably-sized 3-P motors. The 'extra' comes from the 'primary' DC generator - same shaft - that drives the armature. That may have near-zero DC load at startup, but does add mechanical inertia & drag.
Same again with the 'exciter' DC Generator for field and control power. Straight belted, no clutch, that also adds some mechanical drag and inertia even if no DC load is yet being drawn.
Result is an at least 'slightly' harder start for the rating of the MG's 3-P motor section compared to a totally unloaded 3-P motor, same size.
The 'hollow state' electronics of the WiaD and Modular differ. Less greedy at initiation than a motor, but do have large transformers to serve and heater filaments to warm-up.
"Monarch Sidney" and any other solid-state DC Drive are gentler yet. Basically all those do is power-up their transistor / IC control electronics section, AND NOT their Thyristor pass-elements, may or may not provide field power right away, but even so, it is but 2 A or less.
Even when solid-state DC Drives are later asked to provide power, and with a fairly aggressive ramp-up, there still IS a ramp-up, or form of 'soft start', so there is no inrush to speak of.
VFD have a capacitor bank to charge, so should see a modestly heavier inrush at initiation than a DC Drive, but far less than an MG.
Bottom line is that fuse sizing goes by Monarch's 'book' for any of MG,. WiaD, Modular, powered systems. Then goes by the DC Drive or VFD maker's 'book' for either of those.
That's roughly five different 'drive' scenarios = 5 different fusing schemes.
Only one will matter for any given single 10EE but it involves activation "speed" of the fuse as well as Amperage rating.
Just be sure to select the 'right' one for your drive, remember to review that choice if/as/when making a major change, and adjust to the new situation.
Ok all fused up. 30 amp one time fuses. Had to use fuse reducers to fit in this box..
Sent from my EDI-AL10 using Tapatalk
