mike.thomas1
- Mar 24, 2015
I have gotten the nerve to finally use the taper attachment to turn a Jarno taper for the spindle. Sadly I do not have the lovely micrometer dial, but Ive made do (if you have one pweeeeeese sell me). I used two indicators, a 2" to watch the traverse and another to watch the cross feed.
While observing and adjusting over and over I noticed that while traversing there is not an immediate travel in the cross feed, almost a half inch before the cross feed would start moving. I tinkered and tinkered trying to solve it but could not determine how to reduce this lack of movement. The machine has been well cared for and the taper attachment will glide like silk back and forth. Am I missing an adjustment which I can take up the slack? I knocked out the taper since I was working from an end, but I would like a bit more confidence on the next go around.
Thanks Gang!
Thanks Gang!
