mpmar_bt
Cast Iron
- Nov 12, 2011
- Central VA, USA
I recently acquired a Hendey Tool and Gauge Lathe. It's the older design with a standard AC motor and the PIV box.
Hoping someone (Hendeyman) can date it from the serial number - 30954.
Poor thing is still on the trailer under a tarp. Good example of how well Fluid Film works - those drips in the serial number picture are water. It had been like that for days before I got a chance to get the tarps off and get it dried out. Still too wet here to get it unloaded.
It came with a four jaw, a really clapped out three jaw, tail stock, taper attachment and a steady rest. All of which is inside out of the rain.
So far the only thing that seems to be wrong is the push button stop on the lower belt/back gear lever is jammed. Someone removed the linkage to the headstock belt/back gear selector lever and only ran it in back gear.
I'll get some better pictures up once I get it inside and cleaned up a little.
