repaint
yea Steve, I hate repaints as well, I would prefer to see the honest wear a machine has.
Charles
I am in the final steps of rebuilding my 1945/1950 CK/KK lathe and a repaint was defiantly required. It appears to have been originally painted tan with orange MONARCH lettering but I am not sure. It was dark grey and before that green/blue. The bed was replaced with a much newer 1950 KK bed with almost no wear.
I ended up having to grind the saddle, compound and cross feed and applied Turcite and then scraped down to original height. The real PITA was the new compound nut alignment. After I turned a new nut and screw and machined off the old nut, it took a fair amount of time to get it aligned with no binding or noticeable friction. Items that were repaired or replaced (new ones made):
- clutch dogs re-machined and new custom keys made to match. Clutch plate was installed backwards and led to abnormal wear and failure of the brake to engage properly.
- complete new tailstock screw with hardened extractor tip. This was a fun one, LH ACME thread with new matching nut.
- complete strip and paint to nice light grey.
- new compound nut and screw.
- safety clutch added to power feed rod that allows for tripping when using power feeds like that found on the 10EE. Also allows for easier carriage removal.
- needle bearings and normal bearings added to TS end of power feed and threading rods. Bushings were worn and this is overkill but fun work. Now closer to later models.
- replacing 3HP VFD and motor with 5HP VFD and motor.
- decreasing top end speed and increasing low end torque.
- new leveling feet and increased height.
Most of this work required use of my recently rebuilt 10EE and now it looks like I will need to revisit carriage height on my 10EE as well as rebuild my B@S surface grinder (after I rebuild the kitchen of course).
Man I miss 12CK lathe!
