rklopp
- Feb 27, 2001
- Redwood City, CA USA
I was turning parts at about 1800 RPM with lots of starting and stopping, and all of a sudden, the spindle wouldn’t start in forward or reverse. One minute it works fine, and the next minute, nothing. The fuses are closed, the circuit breaker next to the module is not tripped, the time delay relay works, the main contactor pulls in, the spindle lock interlock relay logic works. I pulled the module and it ran after a pulse of the start lever, but then quit responding again. There was a big arc, I think from the QSD relay when I pulsed without the module, and I have seen that before, so I don’t think it is the issue. The speed seems to run wild without the module, which is why I pulse it.
I guess I need to tip out the tubes and have a look. Any ideas?
