purplepicker
- Mar 26, 2013
- Lenoir City, Tn
Help!!
I recently completed the CNC conversion of my 1953 10EE (Ward Leonard drive unmodified with 7.5 hp RPC) see
http://www.practicalmachinist.com/vb/cnc-machining/monarch-10ee-cnc-conversion-complete-270004/
Everything worked fine except for the occasional split thread when running a thread program. I hooked up a scope and found that as I suspected there was an occasional noise spike making its way into the spindle index input of the controlling computer which made the controller think it was time to start the thread.....analogous to closing the half nuts at random.
I was able to greatly reduce but not completely eliminate the problem by covering the spindle encoder cable with braided sheath. By sheathing the cable I am basically treating the symptom rather than the disease. I really need to reduce the motor and or generator brush noise at the source.
Has anyone here attempted, successfully or not, to suppress the arcing EMI on their 10EE? I have obtained a half dozen Sprague .05 mf 600v "bathtub" caps that I intend to put across the brushes on the motor and generator. I think it will be tough to mount them very close to the brushes so they will probably have to go in the DC control box.
I was unsure where to post the question here or on the CNC forum but since I got so much help here when getting the machine up and running in its manual mode I thought there might be a source of similarly vast knowledge in the electrical area of this machine.
Any help greatly appreciated.
Cecil
Cecil
