Hello,
I'm a member of the board for a. It for profit maker/hackerspace in Alberta Canada. We have the opportunity to pick up a donation of a 13EE (15.5" swing and 30" between centers),
From my research and from discussions with Monarch I aware this is a great old lathe. Very capable, precise etc etc.
It doesn't have any of the electronics or drive but the plan would be to put in a vector duty motor and a VFD. That part should be easy.
The problem is gearing. I believe the quick change gearbox is either Imperial or Metric. Currently it has imperial gears in it. Monarch has gotten back to me with an estimate of 15-20k USD for the 10 gears.
If we want the ability to cut metric threads (this is Canada and as a diverse group of hobbyists I think that's close to a must have) are there any other options? We simply can't spend that sort of money on the gearing.
If we know the geometry and tooth counts for the gears could we have them made? (The local polytechnic might be able to help us out by cutting gears).
Any advice or comments are welcomed. To say I'm out of my depth on this would be an understatement!
Thanks in advance.
Thanks in advance.
